It is currently Sun Aug 03, 2025 10:49 pm
 Post subject: New Tool For Lutherie?
PostPosted: Sat Feb 14, 2009 9:34 am
First name: Nelson
Last Name: Palen
http://cgi.ebay.com/NEW-Marathon-103-Surveyor-Milling-Machine-Dental-Lab_W0QQitemZ290295518445QQihZ019QQcategoryZ71377QQssPageNameZWDVWQQrdZ1QQcmdZViewItem#ebayphotohosting
This surely would be useful. Just can't figure out exactly what for.
Nelson Palen
PostPosted: Sat Feb 14, 2009 10:07 am
First name: stan
Last Name: thomison
City: branson
State: mo
Zip/Postal Code: 65616
Country: united states
On a larger scale would be great as a binding ring. It looks in many ways like the rigs Bryan Galloup has for big routers for that. I have the plans and although this is much more high tech. same kind of concept. Might be able to use it in inlay (don't know as only use gringer held in hand.
PostPosted: Sat Feb 14, 2009 11:42 am
I rigged up a Dremel drill press as a pin router for logos but this would probably need quite a bit of modification to do that. You'd have to get your hands on it to see if it would work. You could probably find one at your local dentists lab and play around with. Dental tools are always cool. The logo pin router thing thing works well if you can get a negative template made for your logo.
TJK
PostPosted: Sat Feb 14, 2009 3:12 pm
Terry, where did you get the template made for your inlay? That's exactly what I want to do with mine.
PostPosted: Sat Feb 14, 2009 5:01 pm
Rod,
The guy that CNC's my logo did it for me. I think anyone that CNC's logos could easily make the reverse template. Mine is Corian.
TJK
PostPosted: Sun Feb 15, 2009 1:35 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
Not to appear dumb, but how would one use that template to cut the logo into the headstock.
Fred
Fred Tellier
PostPosted: Sun Feb 15, 2009 8:48 pm
The head plate sit above the template and the template sits with the routed part face down. It sits over a pin in the base the same size as the router bit being used. The router is set to depth and the template and head plate is guided by the pin. Thus a pin router. You can make one out of a universal binding machine if you have one too.
I don't think it is in the picture he shows.
